I’m struggling to understand how to construct schedules in FPL-118 and what is published in both FPL-118 and the Nyle manual for the L-35. Note, I did find some typos in the Nyle schedules and in FPL-118. Also provided Nyle that feedback. However, the real issues are understanding how to assemble a proper schedule per Page 77 in FPL-118 and the associated tables.
Second issue is temperature. The schedules appear to be all over the map and contradict each other. some white oak dry bulb temps start at 110 and some start at 90 degrees F.
For this discussion I am drying white oak (8/4 and 12/4). I’m attempting to construct schedules for green white oak for both thicknesses. I realize there are notes to Air dry to below FSP, but in my area, the climate is so variable that air drying produces surface checking for the thickness I am drying. I understand shade screens, sheds, etc., but the best environmental control is a kiln with automation. I do not care how long it is in there. My goal is little to no degrade. I want to start with green in the kiln.
There are many references to holding temp control to precise values, but there are references that start at 110 degree F (T3 in Table 7.5) and some that start as low as 90 degree F (dehumidification on page 95 and the Nyle schedules). So the thesis of maintaining tight temp control below FSP (~30 MC) seems to be false within this range of starting points. Both references in FPL-118 to white oak (8/4 and 12/4) use T3 which starts with 110 degree F. Yet there is a steam to DH comparison on page 95 that shows red oak starting at 110 and 90 respectively. This makes no sense as temp is temp regardless of what generates it. What is consistent on Page 95 is the RH for both steam and DH. Yet Nyle schedules raise the RH in the alternate schedules if the temp is raise by 10 degrees. This is not consistent and contrary to page 95 in FPL-118.
Since I am drying white oak from green with initial MC of 64%, I went into Table 7.6 and came up with a 9 step schedule (column E). That did not work. The resultant EMC values went crazy. I attempted a T1-E1 schedule. The EMC were: from 18.9 (normal) down to 0.2, but went back up to1.7 and 2.2. Notwithstanding, achieving 1% RH is not achievable and ridiculous.
On page 98, there is a reference to 12/4 white Oak, recommending T1-B1. I assembled that, and it was reasonable, but there is a slight typo. Step 4 should be 110 degrees F.
So how does one assemble a schedule from Green MC, which should be a 9 step schedule in Table 7.6. What am I missing here? How is B1 on page 98 chosen?
Finally, if heat helps extract the moisture from the core, should not thicker wood be better off with a higher temp of 110 verses 90 degree dry bulb at the beginning?
I can’t find a good or consistent reference to target RH for current load. Drying 12/4 white oak with probes showing 35% MC on wettest probe. Goal is average drop is 0.5 MC per day. Current RH is 60%, 110 degrees, 10.0 EMC, seems to have stalled. T1-B1 would call for 100 degrees and 86% RH or 17.4 EMC, which is crazy high. Nyle shows 110 degrees, 65% RH, and 10.9 EMC for the same MC state.
Any guidance is appreciated.
George
