Sawing and Drying
Chainsaw mill
11/13/17
Weasel Member
I'm thinking about getting a chainsaw mill. Will a 60cc.chainsaw be sufficient to rip logs and how long does it take to process a 10' log with a diameter of 24" with a chainsaw mill
11/16/17       #2: Chainsaw mill ...
No responses to Ill toss one out though we dont run chainsaw mills but one of my employees does.
My input is 60cc will be very slow but possible. If your running hardwoods your processing time for 24" diameter logs is going to be extremely long. Perhaps almost a full day to fully process a 24" diameter hardwood log. You will have tremendous amounts of waste due to the width of cut with the chainsaw and, again, to be clear, it will be slow.
I believe he is running a saw perhaps the same size if not slightly larger, and with setup of a ladder for slabbing, re-sharpening often (even with a ripping chain) he says its painfully slow to saw and they are sawing pine (soft woods) almost exclusively).
We run a bandmill and he now brings all his logs to the mill to saw other than the ones he needs to saw in the woods if he has no way to get them out.
My experience is chainsaw mills are great for logs that are too large for most band mills (but you'll need far more tha 60cc's) and they are good for logs that may be in a difficult spot and its better to break them down in place.
Just my perspective.
11/18/17       #3: Chainsaw mill ...
Weasel Member
Thanks Mark. Thats very helpful
8/7/19       #5: Chainsaw mill ...
Trever Jones Member
When it comes to chainsaw milling, the bigger the motor the better. This type of sawing should be left to personal use and larger logs that are not accessible for a bandmill in my opinion. I use a 111 cc saw and it is slow go; not for production use at all. It's very rewarding however, for me an occasional woodworker who comes into contact with large logs 28" + .
9/13/21       #6: Chainsaw mill ...
Joseph M. Harwood
A excellent chainsaw has a saw kerf of about 3/8 of an inch, making it inefficient and producing a lot of sawdust. As a result, a chainsaw mill should never be used to maximize the amount of lumber that can be extracted from a log.
9/13/21       #7: Chainsaw mill ...
Joseph M. Harwood
Website: https://games.lol/standoff-2/
click here to continue
8/10/22       #10: Chainsaw mill ...
KellyP
Website: https://fingerlakesrealtypartners.com/
So the best saw for chainsaw milling would be the biggest you can afford. I recommend a 90cc to 120cc chainsaw if money isn't an issue. These saws are sleek, professional logging saws designed for heavy-duty logging and will provide you with the smoothest milling experience possible.
3/8/23       #11: Chainsaw mill ...
Nelson A
Website: http://www.housecleaningcolumbus.com/
Thanks a lot for posting this, ho w do this kind of mills work? And why are they better than a normal chainsaw?
