Sawing and Drying
Temps and humidity
7/21/23
Rod F  Member
I have my solar kiln (VT style) up and running here in Texas, and it is getting hot. Just wondering if it is getting too hot. On a good sunny day here, the kiln will show up to 150. That's with all my vents open and fans running. On average, it stays around 130-140, with humidity going down as low as 10% to 18%. At night it is only going down to around 100, with humidity coming up to 30%. I am still learning and just want to ask if these were good numbers. Any suggestions and help would be appreciated.
7/22/23       #2: Temps and humidity ...
They are not good numbers for a fresh load. You absolutely can't start a cycle at 150 degrees. In fact all the numbers are too extreme. You need to tarp over at least half the collector, maybe more. 150 degrees is good for a sterilization cycle after the wood is dry. But at 130-140 and humidity below 20%, you'll be making firewood.
7/22/23       #3: Temps and humidity ...
Rod
My apologies, I wrote my question in hast. I am air drying first for about a month. The wood is around 30% when I put it in, some less. The 150 is air temp inside the kiln and I am trying to figure out how to test the internal temp of the wood. I have a mix of post oak, pecan and black walnut. It’s been in for around two weeks now with some down to 9% and the thick oak 2 1/2 “ is at 17%. I just don’t know what good numbers are for a solar kiln. I have a lot of bugs in some mesquite that I will be trying to kill in my next load. I was wondering if you think I can get hot enough to do the job. I am about to retire and plan on doing some sawing -drying as a part job. Can you drill a hole in the wood and use a meat thermometer to check internal? Thanks for any advice
7/22/23       #5: Temps and humidity ...
Safe drying rates are provided in the VT design and operation manual.
7/28/23       #6: Temps and humidity ...
Rod F  Member
Thanks, Rich I will print it out again and see if I can follow.
