Sawing and Drying
Wood type Identification
11/4/23
C Member
I was told the slab was Sequoyah but it doesn’t smell like a redwood. Can anyone tell me what it is by the picture?
11/6/23       #2: Wood type Identification ...
The multiple lines within the dark grain rings makes me think this is willow or elm.
11/9/23       #3: keithnewton@mac.com ...
Keith Newton
Your pics aren’t sharp enough to make a good call. Is that as close as you could get?
From that distance I’m guessing a it’s a hardwood, but you don’t mention weight or hardness?
Did the seller actually harvest and saw the tree?
11/12/23       #4: Wood type Identification ...
Brian Benham  Member
Website: http://www.benhamdesignconcepts.com
It might also help in identification, if you could provide a picture after wiping some water on it so we can see what it might look like with finish or not freshly milled
11/12/23       #5: Wood type Identification ...
Keith Newton
Also, the little zigzag that Tom mentioned in elm is easiest to see in a smooth end grain cut.
11/29/23       #6: Wood type Identification ...
Pete Anderson Member
Website: petesfloors.wordpress.com
Hackberry has this type of grain pattern.
12/30/23       #7: Wood type Identification ...
Pete Member
Could those be Ash?
1/23/24       #8: Wood type Identification ...
BH Davis  Member
Perhaps Butternut.
12/9/24       #10: Wood type Identification ...
Dale Stansbery
I'd almost bet that this is a sapwood slab of Metasequoia glyptostroboides or Dawn Redwood. The bark inclusion at the knot would be typical for the way this tree has deep vertical indentations of bark enveloping the limbs. I have a 50 year old one that I planted in the 70's and the limbs that I trim are the same very light color as this slab. A slab or two deeper would probably reveal the pink color of the heartwood.
12/9/24       #11: Wood type Identification ...
Dale Stansbery
Here's a photo of the lumber.
View higher quality, full size image (800 X 621)
9/2/25       #13: Wood type Identification ...
H LC Member
Website: http://www.hlc-metalparts.com/
The grain is straight and clear, and looks very much like pine or Ash.
