Sawing and Drying
LUMBER GRADES
6/3/24
Gary
I'm wondering if there is a grade of white oak that is better/higher than FAS PRIME ? Also if there away to buy the lumber that is sold to veneer
companies? I assume they get the best stuff that I want !
thank you
6/15/24       #2: LUMBER GRADES ...
Dave Edgerton  Member
Select would be the top grade. Plus you would need the cut such as flatcut, rift, quarter.
As for veneer, they buy the green logs and they remain green and then steamed before veneer slicing. No lumber involved.
6/29/24       #3: LUMBER GRADES ...
kevin Basto
You could buy veneer logs and slice them into lumber, this would be an expensive exercise, but not impossible if you have enough cash...generally veneer logs are auctioned to the highest bidder.
2/24/25       #5: LUMBER GRADES ...
loveisblue Member
Yes! There are grades of white oak that are even higher than FAS Prime, though they might not be widely available through standard lumber suppliers. Here are some options: Higher Grades of White Oak
Super Prime / Ultra Prime – Some mills and specialty suppliers offer a step above FAS Prime, with even fewer defects and better consistency.
Veneer Grade / AA Grade – The absolute best logs are typically sold to veneer manufacturers before they ever reach lumber markets. These logs have minimal defects, perfect grain, and uniform color.
Quarter & Rift-Sawn Selects – If you're looking for super-premium material, quarter and rift-sawn white oak with top-grade selection can be better than FAS Prime in terms of stability and appearance.
Buying Lumber Sold to Veneer Companies
Yes, you can sometimes access veneer-grade logs or flitches, but it takes some extra effort. Here’s how:
Contact veneer mills directly – Some veneer mills sell logs or flitch-cut slabs to high-end furniture makers.
Specialty hardwood suppliers – Some boutique suppliers cater to fine woodworking and may have veneer-grade boards.
Log auctions / Specialty log brokers – Veneer-quality logs often go to auction before being processed. You might be able to source one through a broker.
High-end sawmills – Some sawmills work with veneer companies but may also sell top-tier lumber separately.
If you’re after veneer-grade white oak for solid woodworking, searching for "veneer-quality flitch lumber" or "premium quarter-sawn white oak" from specialty suppliers might get you closer to what you want. Let me know what you're using it for, and I can help refine your search!
_________________________
6/24/25       #6: LUMBER GRADES ...
John
Talk to your lumber supplier about exactly what you need. Most of them are willing to do a special sort for a mark up to give you exactly what you want. This has worked for me on walnut, and has reduced the waste from defects more than enough to cover the mark up on the lumber.
