Sawing and Drying
RE: Bandsaw blades breaking
7/3/20
Tommy Hart Member
We are having problems with our bandsaw blades breaking on a large horizontal bandsaw with 30" wheels, in which we are cutting hardwoods, primarily red & white oak.
We currently use Woodmizer Turbo blades which are 1 1/2 inches wide, 7/8" toothspacing, .055 thick.
Our question is if we set the blades by increasing the kerf on the blade, will our band blades break less?
What is causing our bandsaw blades to break?
Also, what is the ideal kerf to be used in cutting hardwoods?
Thank you.
7/4/20       #2: RE: Bandsaw blades breaking ...
Breaking at the weld or in the gullet? New blades or resharpened? Power feed I assume? Just recently an issue? Change supplier to get this batch? First thought is that you are entering the stock too fast. Try to start the cut slowly and then speed up. If a very recent problem, could be a bad batch of steel. Contact Woodmizer.
7/7/20       #3: RE: Bandsaw blades breaking ...
John Member
Have you checked the actual tension in the blades after you install them? I had no clue what the tension was in my blade; just followed the saw maker's guidelines. After a friend had several blades break on his mill I checked the tension on mine as reference. 24 ksi is what I measured, repeatably. I was shocked it was that high, but data don't lie. I've had just one blade break so far and it was one I had resharpened at least twice.
John
5/16/25       #5: RE: Bandsaw blades breaking ...
Joe Savino Member
Blade breakage on a large horizontal bandsaw cutting hardwoods is often due to excessive stress from heat, improper tension, wheel alignment, or feed speed, not typically the kerf alone. Increasing the set (kerf) slightly can reduce friction and heat buildup, which may help reduce breakage, but it's not a guaranteed fix.
For hardwoods like red and white oak, an ideal kerf is typically around .100 to .120 inches, depending on blade thickness and set. Since you're using a .055" thick blade, each side should have about .020–.030" of set. Too little set can cause binding; too much can weaken the tooth and shorten blade life.
Also double-check:
Blade tension
Wheel tracking
Guide alignment
Feed rate and lubrication (if applicable)
If the problem persists, consider a thinner blade or different tooth geometry for hardwoods.
