Sawing and Drying
End checking in mahogany panels
1/29/26
Walter Goodman
Website: http://waltergoodmancabinetry.com
I have been producing mahogany panels for ten years or so for an artist, who requires one-piece panels, in this case 16" x 20". I am pretty sure the current order will be the last of the 5/4 Honduras wide boards I will ever see, as after a fairly wide search, I lucked into a few boards.
The problem is that we are in a record-breaking cold snap in the Northeast, and the centrally heated loft my shop occupies has extremely dry air, and I can't control the heat. I cut the panels 1" oversize in length, my usual practice. But end checks are developing in a lot of the panels, some more than 1" in. The panels are in the first stage of milling, with 3/32" thickness left to plane in the final pass. I have been dousing the end grain with water, and last night I stacked them with stickers and wrapped the ends only with plastic. This seems to help, as some of the cracks started to close, but a new one also developed.
Any suggestions appreciated. Continue to wet the ends every day until the MC equalizes, or the central heat diminishes? Get a humidifier, which I have not done because we have 9,000 sf and 14 ft. ceilings... make a tent? Seal the ends, if so with what? Eventually the ends will have to be cut, and I only have 1" of trim.
1/31/26       #2: End checking in mahogany panels ...
Bill Smith
Website: http://esf.edu/nekda
Most typically end checks, even in dry boards and panels, originate due to rapid drying from ends when lumber is/was green. Control techniques include stickers close to ends, wax, like Anchor Seal, burlap or Shade-dri, end trimming, and such. Curing of end checks is only possible by trimming away. Applying moisture to ends can make end checks appear to close, but usually results in driving the crack deeper such that damage later will be even worse.
1/31/26       #3: End checking in mahogany panels ...
Walter Goodman Member
Thanks for your reply. The weird thing is these kiln-dried boards tested at 6 to 7% MC with my pin-type meter. I guess that's a testament to how awfully dry the indoor air is when it's 10 degrees out and you are in an overheated environment.
9/16/26       #4: End checking in mahogany panels ...
David William  Member
I’d avoid repeatedly soaking the end grain, since adding and removing moisture can create additional movement. The immediate priority is slowing the moisture loss. Sealing the end grain with a good commercial end-sealer (such as Anchorseal) would be my first step, especially with only 1" available for trimming. Keep the panels stickered with good airflow around them, but reduce exposure to the heated, extremely dry air. A temporary plastic tent around the stack, with some controlled humidification, may work better than trying to humidify the entire 9,000 sq. ft. space. Let the moisture content stabilize before final milling.
9/27/26       #5: End checking in mahogany panels ...
Bibi Member
Damn, dry heat and wide mahogany is a losing battle.Keep wetting, tent them, and pray, good luck
