Sawing and Drying
Re-sawing problems
3/29/26
Mark Elliott
I am having terrible problems with the board I am re-sawing drifting away from the fence on a Stenner saw.
At the beginning of the cut, it immediately drifts in toward the fence then after a foot or so tends to straighten out. Even after it starts to cut "more evenly", there are still bellies and hollows in the board.
I am using a 3" blade tensioned according to the gauge at 2400 lbs, which is probably on the high side, and re-sawing 5 1/2" wide red oak boards trying to get 7/32 " skins. The feeder is set at the slowest feed rate and I have tried a different blade getting the same results.
Has anyone encountered this problem or recognize these symptoms?
Any help or advise would be greatly appreciated.
Mark
