Sawing and Drying
7/4 Red Oak Redry
4/1/25
Cyrus Moats
2 years ago we dryed 7/4 Red Oak on stick down to 6% to 8% and never took it off stick the Moisture now is 10% to 12% can I redry at 120 degrees back to 8% and can I get any new defects or checks thanks Cyrus
4/16/26       #3: 7/4 Red Oak Redry ...
Daniel Member
Red oak is already tricky enough the first time around, so redrying it two years later is a legitimate concern. At 120°F you should be fine bringing it back down, just go slow with the humidity schedules — 7/4 stock will check on you fast if you rush it. Also, once you get your drying operation dialed in, tools like Phonexa can help manage the business side so you're not losing track of orders while babysitting the kiln.
