Sawing and Drying
Vertical vs. pivoting crosscut saws for lumber units - what I've learned ov
10/19/26
Brett Crowe Member
I spent nearly three decades building and servicing chain saw cutoff machinery for lumber and pallet yards. A question that comes up a lot when trimming lumber units: is it better to drop the bar straight down (vertical/guided crosscut) or swing it on a pivot? Both work. Here's how they compare in practice.
Where vertical cutting shines
- Square cuts top to bottom. The bar travels straight down a guide, so the cut stays perpendicular through the whole unit. Pivot saws cut in an arc, and on tall units that can leave the end slightly off-square or "scooped" at the top and bottom.
- Even chip load. On a vertical stroke the chain sees roughly the same amount of wood the whole way down. On a pivot, the amount of bar in the cut changes through the swing, so chain and engine load rise and fall.
- Less bar and chain wear. Steadier loading and better bar support usually mean less heat, less rail wear and fewer thrown chains.
- Repeatable trim. A fixed cut line makes it easier to set stops and hold the same trim on every unit.
- Safer, more predictable motion. The bar moves in one straight line inside its guarding instead of sweeping an arc.
Where pivoting still makes sense
- Simpler build and lower cost
- Fast cycle times on shorter units
- Fewer guide parts to maintain
- A good fit for portable yard saws where speed and mobility matter more than a perfectly square end
Bottom line: for tall lumber units or when accurate, repeatable trim matters, vertical cutting is usually worth the extra cost. For general yard work and pallet stock, a well-maintained pivot saw is hard to beat.
What's everyone running on their units? I'd like to hear what's worked, or not, in your operations.
