adhesive of sanding conveyor belt -- 0 --
7/21
I have a Time Saver top 30 wide belt sander. The rubber conveyor is separating at the seam. Time saver no longer supports this machine. Is there some type of adhesive I can use to patch this togeather, or another source for belts.
7/22 #2: adhesive of sanding conveyor belt ...
McLeod Belting Co High Point NC
7/24 #3: adhesive of sanding conveyor belt ...
If it is a rough top conveyor make sure to stick with natural rubber. Also, if you buy a laced belt, make sure they skive away all the rubber on the seam and use the thinnest splice possible. Otherwise you can't dress the conveyor.
Endless is better if you are inclined to mechanical work.
9/10 #4: adhesive of sanding conveyor belt ...
I have had good luck repairing some sander conveyor belts with Hardman Urethane adhesive # 04024. It comes in a ready to mix package, and is similar to a 5 minute epoxy as far as thickness and application. This will not fix a belt that is going to split completely in half, but sometimes these belts seem to delaminate and start developing a flap. Like any glue, everything must be clean before you start. If you position the belt so it is at about 3 o'clock on the infeed table roller, the split will be more open so you can get the glue into the crack. Then advance the belt until it is horizontal so the glue does not drip and can set up.
Lay a heavy weight on top of the area, or put a big clamp on it to keep the repair flat. Slip waxed paper under the belt to avoid gluing the conveyor belt to the machine.
4/24 #5: adhesive of sanding conveyor belt ...
Website: http://sandersunlimited.com
I would STRONGLY discourage you from using a "clipper laced" belt unless its only temporary. Yes it is less labor to install especially if you machine is in line with other equipment and access to pulling the bed assembly out is limited. However what is not taken into consideration is the damage the metal lacing does to your conveyor bed plates. As the metal lacing drags across your bed plates, you are creating friction, metal on metal. Its even worse when you load material on that seam. Now your forcing the metal lacing to create more friction on your bed plates from the pressure of your pinch rolls as well as the abrasive belt. The cost of grinding or installing new bed plates is not pretty. I have had customers spend thousands of dollars to repair the damage these belts create.
Depending where the separation is (on the rubber surface or on the canvas or both) will determine the repair. If the entire seam is separating, any repair you do will be temporary, In my experience once a weak spot is created in your conveyor belt, it's only a matter of time before it completely fails due to the tension used to keep the belt tight to the feed drive roll and also the"pressure" you create when sanding material. If the damage is only related to the top rubber layer, you can try cutting the delaminated/damaged area away and using silicone as a filler. The silicone will be pliable enough to follow the radius of your feed drive and take up rolls.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
