Wide belt contact drum recover -- 0 --
5/24
Looking to get a contact drum off a jet 13" widebelt recovered - has spiral grooves machined in it.
Looking for shop that handles this and recommended material/durometer.
5/25 #2: Wide belt contact drum recover ...
Try these folks. They've recovered an edge sander drum for me.
Western Roller
5/26 #3: Wide belt contact drum recover ...
Make sure who ever does it can spin balance it for you.
On combi head machines 75 shore is just about right. Don't go any softer than 65 shore. 80 to 90 is too hard.
5/28 #4: Wide belt contact drum recover ...
Thank you for the recommendations. The damage to my drive roller is looks to be less than 1/16" deep. I was toying with the idea of turning it down on a metal lathe. I know that will effect belt speed. Should the idler and drive roller be at the same height in relation to the table or is the drive roller lower? I only have platten height adjustment.
Thanks again for your input.
5/28 #5: Wide belt contact drum recover ...
The contact drum must be lower than the idler roller. You don't want the contact roller anywhere near the product.
You can turn it in a lathe but your spin balance will change and you will have bad chatter. The roller companies use a tool post grinder and a nice coarse wheel.
9/25 #6: Wide belt contact drum recover ...
Website: http://sandersunlimited.com
Dave A, an easier solution would be to dress the drum while it is in the machine. There's a few advantages to this. 1). You eliminate potential damage to your bearings if you need to pull them off, which will save you money. 2). If the damage to your rubber drum is 1/16' or under, you should be able to dress it in the machine (make sure it is level to your conveyor belt). If your drum was 37" or greater, then I would recommend you level the drum to the steel bed plates and not the conveyor belt, only because you will have more wear on a rubber belt vs a steel bed plate. That way you're leveling your drum to a true machine surface. What you don't want to do is put any kind of taper in the rubber contact drum, otherwise your abrasive belts will crease and fold over if the taper is significant enough. 3). Dynamic balancing shouldn't be needed when dressing that amount from your drum. You haven't disturbed the plane of the shafts in relationship to the bearings and as far as the cutting speed of the drum after dressing it, i doubt you would even notice.
Now with all that said, Adam is correct about the rubber drum height in relationship to the high speed steel roll. IF your machine is equipped with pillow block style bearings on the rubber contact drum, all you need to do is place shims between the bearings and the surface the bearings are mounted to. The thickness of these shims will be determined by how much you remove from the rubber drum. Hopefully your machine is equipped with a thickness readout. If not, place a dial indicator underneath the rubber contact drum and measure how much one full revolution of the hand wheel for your bed height adjustment is.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
