Solid Wood Machining
Leadermac moulder operation
3/16/17
Seth
Using a 5 head Leadermac moulder and wanting to not use last bottom head. The bed after last head is about .025 higher with no height adjustment. I'm thinking of having bed plates machined down then I can use shim stock to raise back up when needed. Am I missing something here or is this common?
3/16/17       #2: Leadermac moulder operation ...
Duster
I also have a similar 5 head molder and I don't use the last bottom head either since we only use it for S4S. My machine had a removable shim under the bed after the last bottom head. We just unbolted that last section of the bed, removed the shim and bolted that section of the bed back down. With the shim gone, the entire bed became level. I would bet that your machine has a similar set up.
3/16/17       #3: Leadermac moulder operation ...
Seth
I was hoping for a shim under the last 2 bed plates but no such luck. I'm just getting it set up and learning, also hoping to use it to S4S.
3/20/17       #4: Leadermac moulder operation ...
Russ
Website: http://www.mr-moulding knives.com
If there is no shim, then there has to be some kind of adjustment on the casting near the last bottom, something that has settings of .0, .5 and 1, I have seen it on the machinery. The machine must be able to plane off the lubricant used in the milling process. Look around the back end near the outfeed table you will find it.
All the best
Russ @ Mirror Reflections
3/23/17       #5: Leadermac moulder operation ...
Tom
Website: http://www.leadermacusa.com
Hi Seth, I am with technical support @ Leadermac. If you remove the last bed plate there is a brass shim under it. It is removable. If you remove it and re-install the table it will then be level. If you need any assistance give me a call at 1.866.522.6835
3/23/17       #6: Leadermac moulder operation ...
Tom
Seth, I did not see the thread where you said you looked for the shim. Give me a call to discuss as I am sure we can assist. 1.866.522.6835 ext. 5022
3/28/17       #7: Leadermac moulder operation ...
David Waldmann  Member
Website: vermonthardwoods.com
Yeah, I have never heard of a moulder where the bad plate after the last bottom did not have a 0.020" or so shim under it, so that you could remove the shim and not use the last bottom (or in some cases, use the last bottom for splitting-only, or who knows what else).
