Solid Wood Machining
Weinig Powermat
4/27/17
What is a realistic setup time that can be expected with a new 6 head Weinig Powermat with the HSK spindles and NC positioning of the spindles?
Any users care to comment?
4/27/17       #2: Weinig Powermat ...
Chad Hunter  Member
Website: islandshutter.com
Are you asking the question on time based on the machine positioning itself. I have a 6 head unimat with positioning on the last top and left head. I could set up my P-23 much faster but it often took several test pieces for set up. The new moulder takes a few minutes longer measuring the tools optically and clicking on computer but that time is quickly made up with the first piece out being near perfect. Some setups naturally take more time changing the width of feed rollers or repositioning fences.
4/28/17       #3: Weinig Powermat ...
Russ
Website: http://www.mr-moulding-knives.com
I was a Weinig Tech for eight years, this is the most common question I would get from management on every install.
My answer was always this.
Be more concerned about the operator learning the machinery and being safe at the same time producing a great product.
There is a learning kerf for everyone in everything we do. This attitude approach will keep everyone safe, produce an outstanding product, and keep the machinery in good working condition.
Now, in time you see the operator is just taking way too long to set up the machine, it might be time to look for a new operator.
During Weinig demos, the set ups are performed by professionals with many years experience, it's not realistic to expect everyone to set up the machinery in the same amount of time.
So kickback, relax, and concentrate on operator safety and awesome looking mouldings. The set up time will slowly decrease as the operator is more comfortable with the machinery.
All the best
Russ @ MR
4/28/17       #4: Weinig Powermat ...
Let me ask the question a different way. Not second guessing an operator but deciding if the added expense of the NC positioned axis's, measuring equipment, HSK heads.... is worth it. Would it enable more change overs and thereby allow you to make shorter runs more profitably?
4/28/17       #5: Weinig Powermat ...
Russ
I happen to be old school moulder operator.
I can set up a moulder in almost the same time as a fancy moulder with all the bells and whistles, let's say maybe a five minute difference realistically.
Now the question is this, how many setups will it take to pay the difference in price from a plain Jane machine, versa a moulder with all the bell and whistles.
Don't forget you will now have more moving parts and more things that could potentially go wrong over time. Technology is always changing, what we buy today is out of date tomorrow, so computers on moulders today will be rapidly outdated in the life of the machinery.
It's a tough choice and needs some serious consideration. I have clients with the machinery you're describing and they love them. Weinig has always been a leader in moulder operations, the best thing to do is talk to the operators of the machinery, they know the most about how the machine performs.
I hope that helps
Russ @ MR
4/28/17       #6: Weinig Powermat ...
Russ
Bill This is just my opinion, and we all know what they say about opinions. I would buy higher RPM machine, like 8,000 or 10,000 and increase my feed rate to quicken the smaller lineal foot runs, 40-45 feet per minute for 8000 rpm and 45 -50 feet per minute for 10000 rpm. I posted an article that explains it better Have a good weekend Russ
Moulding Knife Marks
5/23/17       #7: Weinig Powermat ...
Russ you article says that 90% of the moulding made today is made with a round cutterhead. What is the other 10% made with moulding planes? Extruded MDF?
5/23/17       #8: Weinig Powermat ...
Russ
Older moulders that use square cutter heads
8/24/17       #9: Weinig Powermat ...
David Waldmann Member
Website: vermonthardwoods.com
I could well be wrong, but I don't believe you can get a Powermat without NC controlled top/left heads. You can't even get one without a computer of some sort - their default is PowerCom and you can downgrade to the [whatever the cheaper one is].
We didn't want a computer on our new moulder. Had/have a Unimat with PowerCom (but all manual heads) for 11 years and wished we hadn't gotten the computer. Just ordered the Powermat 700 on Tuesday with PowerCom because the cheaper system is still a computer and at least we know the PC and we can transfer all our info over to the new one.
Going back to the original question, setting up our 5-head Unimat with conventional spindles can take anywhere from 3 minutes* to 3 hours depending how many heads need to be changed, bedplates replaced, chipbreakers moved/changed, special pressure shoe adaptations, feed rollers moved/changed, and probably other things I can't think of right off.
*a lot of our profiles are variations using the same knives, so we may be able to make a new profile just by changing the thickness, width or axial position of either the top, left or right head.
