Solid Wood Machining
Making Rounded Coffin Top
7/5/17
Woodworker Member
Do you have any idea on how to make rounded coffin Top?
Thanks...
7/5/17       #2: Making Rounded Coffin Top ...
Keith Newton
Could you be more specific?
Are you wanting it to be cylindrical, or domed?
7/6/17       #3: Making Rounded Coffin Top ...
Woodworker Member
Dear Sir,
Like the coffin below. I was a part-time woodworker since 2 years ago.. Till now I am only able to produce near to 100 basic coffin... Now I wish to explore something new to me. Please help as no one guide me. Thank you.
7/6/17       #4: Making Rounded Coffin Top ...
Woodworker Member
The tools that I have :
a) 16" Jointer
b) 5", 12", 16", 30" thickness planer
c) Circular saw
d) Hammer, Battery screwdriver
e) Clamps
f) a Makita router
what's all I have..
7/7/17       #5: Making Rounded Coffin Top ...
What do you need?
More tooling and more experience.
The lid is a traditional stave built curved lid. Pieces are molded or beveled on joiner to make the proper radius. Then, a large specialized saw is used to cut the ends and let in the curved returns. The rest is basic box making, and there are hundreds of ways to do this.
Can you post you drawings on the box? We can tell you what would be next.
7/8/17       #6: Making Rounded Coffin Top ...
Leo G
https://www.youtube.com/watch?v=HGbVbsSfBSY
7/9/17       #7: Making Rounded Coffin Top ...
ccting Member
Hi Mr David ,
. Pieces can be beveled on my joiner to make the proper radius. I am thinking on how to cut the V shape using my 9 1/4" makita circular saw without any defect.. Anyway what isthe name of the large specialized saw ?
Any simpleat domed shaped casket lid Sir can teach me :)
Thanks very much
7/9/17       #8: Making Rounded Coffin Top ...
Leo G
With a jig and a large band saw, you could make the cuts pretty well.
The saw is just a large blade and they made a jig to push the coffin into the blade at a 45.
If you look at wooden coffins, the joints are good, but they aren't spectacular.
7/10/17       #9: Making Rounded Coffin Top ...
Keith Newton
I think you should consider finding someone with a molder who could mill your parts for you. The image you show has a step which would allow you to make two separate frames which could be fastened together from the underside after they are mitered and glued.
It may even make it easier to have 3 parts per side, which might make the miter and joinery easier.
Another easier way to join up curved glue-ups, it to mill a half-round on one edge of the staves, with a cove or flute of the same diameter on the other side. This eliminates the need to cutting bevels that need to be perfect, since it acts like a hinge for any angle.
To glue these parts into an arc, you just need to make a few matched identical concave templates which are made into a fixture. At one end of the arc, leave a tab sticking up for a stop. at the other end, the clamp pushes the last stave, by pulling against the template. I usually just drill a large hole underneath, more or less along a tangent to that last stave.
7/14/17       #10: Making Rounded Coffin Top ...
woodworker
Thanks to Mr. Leo and Newton,
Most of the info is already in my mind, but still I don't dare to try...
Anyone could make a video on how to make dome casket lid limit to the use of Jointer, 91/4 " circular saw and custom-made Jig?
Thanks again..
8/3/17       #11: Making Rounded Coffin Top ...
Read
Small point, but what you are a making is a casket. Coffins are the ones that taper in both directions from the shoulders. Caskets are rectangular.
