Solid Wood Machining
Reference engraver on a moulder
3/5/18
Bob
What is the purpose of a reference engraver on a moulder?
3/5/18       #2: Reference engraver on a moulder ...
Russ
Website: http://www.mr-moulding-knives.com
Bob To act as a guide and shorten the distance of unsupported lumber between the end of your infeed fence and first right cutter head. I have attached an article below to help you with alignment. Hope it helps Russ @ MR
Article
3/8/18       #3: Reference engraver on a moulder ...
David Waldmann Member
Website: vermonthardwoods.com
Not to take away from Russ' article, but for MOST purposes, we have found that the reference engraver is more theoretical than practical. In face, Weinig doesn't even include them anymore (haven't for over 10 years). I bet you could have them add it, but as far as I know it's not even a listed option.
Make your blanks flat and straight (and you can do that much better and easier with equipment designed to do that) and you eliminate any need for it.
4/8/18       #4: Reference engraver on a moulder ...
Rob Scaffe  Member
The rebate cutter and associated fence in theory act as a jointer to provide a straight edge and support as the timber enters the right spindle.
With that said, there are unintended consequences if you remove them. You will be left with a large gap between the infeed fence and the fence after the right spindle which will probably result in snipe on the right side. You will need to either replace the infeed fence with the version with an adjustable lip (an expensive option) or have the existing fence modified.
Correct setting of the alignment of the rebate cutter to the fence and shimming to the bottom cutter head to provide an overlapping cut are critical, but not that much trouble for a competent operator or owner. Russ probably can provide an article that describes this procedure.
The biggest problem with the rebate cutter is low functioning, untrained operators and poor machine maintenance.
Best of luck
Rob
4/8/18       #5: Reference engraver on a moulder ...
Rob Scaffe  Member
Whoops, I see Russ already posted the link.
