Solid Wood Machining
Sharpening Circular Saw
5/17/16
TCC Member
I am used to sharpen my own sharpening saw by hand, using some own make jig. The result is great, but the sharpness cannot last long. And, for wood that is harder than IronWood that is more than 1" thickness, sometimes it causes burning even i pour some oil on the wood and blade. Then i notise that the burning area (body) is under the blade tip. It seems that there is high friction between blade body and thick hard wood.
I sharpen my blade on face and top, but never on side clearance edge. Anyone can teach me on how to resharpen or reshape the side clearance to large angle?
ty
5/18/16       #2: Sharpening Circular Saw ...
Dave Rakauskas
Website: http://www.csaw.com/grinding
You need to send the blade to a saw shore. There is at least one in every small city in America.
Side grinding teeth is more difficult and takes a different machine than tip grinding. Plus you often need to replace a few teeth by brazing them on if you want more drop
Lastly side rubbing often means your blade needs hammering and tensioning so it will run true at RPM.
Woodworkers can sharpen their own saws if they want and if nothing goes wrong but as soon as you lose a tooth or lose tension or have problems you need to get it to a professional sharpening shop
5/23/16       #3: Sharpening Circular Saw ...
I agree with Dave, send it to a shop to be checked out and put on a machine where they can professionally sharpen it. If you need help finding one, just give us a call.
6/19/16       #4: Sharpening Circular Saw ...
Dan / drbwoodworks
Sent it to Ct saw & Tool , in Stratford, Ct.
4/30/18       #6: Sharpening Circular Saw ...
cowolter Member
Website: https://cozzy.org/best-makita-2012nb-review/
I use a 10" mill file to sharpen the saw. You want to keep your teeth straight. If you get any angle on them, your saw will lead in that direction. I use this method the most. With practice, you can get sharper than with a grinder.
You can invest in a grinder. They can be a little costly if you don't do a whole lot of sawing. I have a Jockey grinder ,they grind all the teeth in the same angle, so there is a more consistent sharpening. There are other ones on the market.
4/30/18       #8: Sharpening Circular Saw ...
cowolter Member
The best part of a good shop is you can get teeth replaced as well.
As my grandfather use to tell me when I was a little kid
"There a guys that do that stuff all day long, why are you trying to screw it up!"
Dremel US40-01 Ultra-Saw
