Solid Wood Machining
What equipment do I need to make solid wood cabinet doors in-house?
8/15/18
gursi Member
Exactly what equipment do I need to start making solid wood cabinet doors in-house. I want to offer most styles. There is probably only going to be 1-2 people making these doors at my shop. so I dont think i need the biggest machines. plz let me know what equipment I will need. Thanks guys <3.
8/15/18       #2: What equipment do I need to make so ...
B
We use the following:
8 Shapers
Stock Feeders
Clamps/Clamp carrier
Drum or widebelt sander
Stroke sander
Table saw, chop saw
Orbital sanders
Routers
8/17/18       #3: What equipment do I need to make so ...
Dustin orth
What's your budget? Are you looking at all new or used? Can you spend some time and sweat equity fixing some older stuff? Give us a little more info please.
8/17/18       #4: What equipment do I need to make so ...
Gary
We make about 50 doors a week with the following,
SLR saw
crosscut saw with Tigerstop
8 Weaver brand shapers (love them)
Clamp carrier
Planer/sander
Sliding tablesaw to square panels
Widebelt
JLT door clamp
edgesander
Good dust collector
downdraft sanding tables
A shape and sand that actually works would be nice
8/28/18       #5: What equipment do I need to make so ...
jeff dana Member
my thought along time ago we had multiple shapers
you should consider a Martin shaper
one machine to do all
you should contact Eddy at Semantect machinery I will post his contact information later
do not forget a wide jointer & power feeder to flatten the stock = same a Martin
9/12/18       #7: What equipment do I need to make so ...
Alex Member
Website: https://rangate.com
Hi gursi,
It's a good idea to think about tooling at this point too. Using insert cutters on your shaper which maintain your joinery will serve you well over the long term. It also makes it cheaper to change out profiles between jobs if you're just changing a knife instead of buying a new set.
The company I work for (Rangate) just developed a stacked toolset for shaker style cabinets since we were getting a lot of calls from cab makers telling us that's what their clients were asking for. You could do a true shaker with adjustable groovers, or invest in a set if you would prefer to save yourself a bunch of set-up time.
It seems like people buying cabinets tend to say they want "Shaker" but also want a slight bevel/chamfer on it. It's one of those terms that has a dictionary definition but also means different things to different people.
We have an option called CutterShare which would let you get our cabinet set for up to 3 months for less than even a brazed set would run you. That could be a nice way for you to get set up to do quality cabinets without committing to any tooling- you can subtract your initial cost to buy the set out if you end up liking it, as well.
Good video overview of the 5-piece build process here: https://www.youtube.com/watch?v=qQGegCGfAV8
CutterShare Cabinet Set
