Solid Wood Machining
Flooring through the moulder Face Up or Down?
11/30/18
Aaron Palmer Member
I read a letter recently that suggested that machining flooring through a moulder face down is better for two reasons:
1. the second bottom head improves finish quality
2. There is further accuracy of the face relative to the tongue and groove which enables you to provide a better product to the end user who will appreciate the easier installation.
Here are my arguments against this:
1. Flooring is installed referencing the the sub-straight, so to me, the floor to tongue /groove tolerance is more important for a proper laying / squeak-free floor.
2. Because the floor in going to be sanded prior to finish application, is the 'fine' finish that important?
I'm sincerely open to everyone's experience and knowledgeable input on this one. Is there truly a right and wrong way? I would love to hear your experiences.
11/30/18       #2: Flooring through the moulder Face U ...
Aaron Palmer Member
I also wanted to add that when feeding the moulder upside down, the feeder has to inspect both sides of every piece to determine which side is best and turn the best side down.
When feeding right side up, if the top looks good, there is no need to flip over to check the bottom. - better for quality and ergonomically
11/30/18       #3: Flooring through the moulder Face U ...
Russ
Website: http://www.mr-moulding-knives.com
Aaron
There is no right or wrong way to mill flooring or any other type of moulding. We have clients mill flooring both ways, face up and face down. Your concerns are valid and debatable but milling it face down, tongue on the outside of the machine would be my preference as well simply because if there are any feed roller marks left in the lumber it would be on the backside and I would still have a sell able product, it would still be milled at the proper thickness dimension so your concerns would not be in play.
But the bottom line is its your shop and you should mill it the way you feel most comfortable regardless of the reasoning. We always try to weigh the pros and cons on every profile we design sometimes we have to mill mouldings certain ways to avoid other unforeseen issues that the client may not be aware of, that's where my operator experience comes into play, we hopefully learn from past mistakes.
Milling it face up will look awesome!
All the best
Russ @ MR
11/30/18       #4: Flooring through the moulder Face U ...
Russ
Aaron
In response to your second post which I forgot to address. The operator should be looking at both sides of the lumber to find the best way to orient it thru the machinery milling bow up in reference to the bed plates and bow out in reference to the fence. Of course yield overrides above statements.
I hope that helps
Russ
12/1/18       #5: Flooring through the moulder Face U ...
Paul Miller
When we mill wood flooring, we always run it face up. When feeding the flooring into the molder, we have to occasionally pump some lubricant on the bed and I do not want this on my face.
12/1/18       #6: Flooring through the moulder Face U ...
Russ
Paul
Any bed lube applied to the bed plates of the molder is designed to be milled off by the last bottom cutter head on the machine, there is a .020" shim under the last bottom bed plate specifically for that reason. Any good quality bed lube is manufactured in a way that if some residue remained on the face it would not harm the finish of the wood, that's one reason it so expensive.
Beside that, if you were using some not recommended bed lube like I have seen numerous times, as stated above the floor would have to be sanded before any finish was applied.
The original poster is looking for pros and cons, your comments above should not be a deterrent from milling face side down, its a personal decision you made and I respect that decision.
Russ @ MR
7/28/19       #7: Flooring through the moulder Face U ...
charles
I milled face down on both push feed type and feed through moulders.
The better the finish and the better the fit, the less sanding in the field.
I have even pre sanded through a widebelt to minimize field sanding .
