Solid Wood Machining
Help. G1012 planer snipe evenly on both ends
2/16/21
Lyle Member
I have a grizzly g1012 planer. I owned it for the past 6 years. Last week I changed the blades and now I'm getting snipe on both ends marked at about 2" in on both ends. Before changing the blades, I had no snipe. Does anyone have any ideas how to fix this problem. While waiting for the original blades to be sharped, I want to fix this problem before replacing the blades with the original ones. I appreciate any input.
2/16/21       #3: Help. G1012 planer snipe evenly on ...
You have set the knives higher than previously. This has changed the height relationship between the knives and the chip breakers and feed rolls.
2/16/21       #4: Help. G1012 planer snipe evenly on ...
Lyle Member
That you for the response. I'm going check the alignment on the chipbreaker and the feed roller. Grizzly suggested checking the bed roller.
2/16/21       #5: Help. G1012 planer snipe evenly on ...
I used to own one similar to yours. They really benefit from the setting up that is written up in the owners manual. It requires making a wood gauge block and using feeler gauges to set the relative height of the feed rolls and chip breakers to the cutter head
2/16/21       #6: Help. G1012 planer snipe evenly on ...
Lyle Member
I believe I found the problem. Keep in mind, I would consider myself as a beginner level wood worker. Almost everything I've learned has come from youtube.com. I recently lubed up the planer, one part Imparticular the threaded rods that raise/lower the bed. During my current build, a bathroom wall cabinet, I didnt lock the bed while planning duh. I used to skip locking locking the bed before I lubbed and it didn't make a difference. I ran a test piece today with the bed locked in, no snipe. Thanks for your quick responses.Live and learn.
