Solid Wood Machining
General 130 planer problem
3/27/21
Dave
The feed rollers on our General 130 planer are not engaging.
I believe we got the clutch on the shaft properly after opening up to have a look.
Has anyone had a similar experience?
4/6/21       #2: General 130 planer problem ...
Roger
There is a roll pin that locks a chain sprocket to the feed roller that will shear. It has happened to me several times and it's not fun to fix. The shaft inside the sprocket gets a bur from the end of the roll pin and it is hard to remove the sprocket. Backing off the feed roller pressure and making sure to not to feed wedge shaped stock has eliminated the problem for me.
11/19/21       #3: General 130 planer problem ...
AcctekChina Member
The paper feed roller is worn out. The paper feed roller is the most abraded part of laser printing. When the paper in the paper tray is normal and paper cannot be fed, the paper feed roller is often worn or the spring is loose. The pressure is not enough to feed the paper into the machine.
