Solid Wood Machining
kerf bending wood, (tapered ball end mill).
9/1/21
michael foster Member
I need to bend some solid wood and I am wondering if it is possible to use a Tapered Ball End Mill in a router to make kerf cuts instead of using the table saw? Can these cuts be made so the gaps close completely and are glued when the wood is bent avoiding having to plug or fill the voids?
9/6/21       #2: kerf bending wood, (tapered ball en ...
BH Davis  Member
I think the only way you would get a perfectly mating joint is if the tapered mill came to a point. If there is any thickness to the tip of the bit you won't be able to bring the two side of the cut in to meet each other. They would become parallel at the point that matches the thickness of the bit tip. If the bit tip were 1/16" thick the two faces would be parallel when the are 1/16" apart.
It would be like trying to make a miter fold joint with a bit that didn't come to a point.
12/13/21       #3: kerf bending wood, (tapered ball en ...
Acctek  Member
Ball-end milling cutters are widely used in all kinds of curved surfaces, arc groove processing, and are also competent for processing complex processing surfaces.
