Solid Wood Machining
Machinery parts for discontinued machines
10/3/21
Mike Gagne Member
Website: http://mauicustocabinetry.com
Does anyone have sources for Sunhill Sanding machine parts?
10/8/21       #2: Machinery parts for discontinued ma ...
Mark
Tough with Asian machines, made to throw away, not service or rebuild.....
Try to find the original manufacturer and see if they have a tech/parts dept (usually not) or try to find other brand(s) that re badged the same machine and then search for used parts.
Good luck
10/20/21       #3: Machinery parts for discontinued ma ...
If American made, check with the manufacturer. Diehl still makes parts for saws that are 50 years old.
Beyond that, machine shops can make many parts or help you figger a way around it.
10/20/21       #4: Machinery parts for discontinued ma ...
You might try Grizzly. A ton of import machines are sold in many colors. If your machine is old, good luck will be scarce.
