Solid Wood Machining
EMA/Casadei shaper spindle bearing replacement
11/24/21
stoneaxe Member
We just got an older EMA/casadei F115 shaper, the bearings could use replacing.
It appears the entire shaft loads into the outer fixed part of the spindle from the top- the odd thing is there is no top bearing cap capturing the outer race of the bearing, as if the entire assembly relied on a press fit to hold everything together.
Can anyone shed some light on this?
View higher quality, full size image (1215 X 845)
11/24/21       #2: EMA/Casadei shaper spindle bearing ...
stoneaxe Member
BTW, that nobbly piece on top of the upper bearing (marked 1), is a "fan", and turns with the shaft and bearing underneath. This is where I would normally expect to see a bearing retainer cap. This fan is trapped by a lip on the shaft, so cannot be removed from above to expose the bearing.
From the drawing, it looks like the shaft could be pressed out of the outer housing without any mechanical resistance save friction. Can this be correct?
11/24/21       #3: EMA/Casadei shaper spindle bearing ...
What I see is a bolt and washer below the stepped pulley that mates with a tapped hole in the bottom of the shaft. Spacers and lock washer are used to tune the preload. It's hard to tell if there is a shoulder on the shaft that captures the fan but there has to be one.
11/24/21       #4: EMA/Casadei shaper spindle bearing ...
stoneaxe Member
Tom,
I think you have shown me the light...
I was looking at this wrong. The top and bottom bearing ride against opposing shoulders in the housing, and the nut puts preload between them.
duh!
Thank you!
11/27/21       #5: EMA/Casadei shaper spindle bearing ...
Gary
I do remember replacing the bearing but it's been too long to be of much help. I do remember that I did have to have the bearing pressed on and off. It was a pricey bearing made in England. I have had mine since new ( 36years) and she has been a great machine.
12/15/21       #6: EMA/Casadei shaper spindle bearing ...
Acctek  Member
To judge whether the bearing can be used again, it should be decided according to the bearing damage level, mechanical performance, importance, operating conditions, inspection cycle and other related factors.
12/15/21       #7: EMA/Casadei shaper spindle bearing ...
Gary
After going through the removal process, you would regret not replacing the bearing. My two cents.
12/18/21       #8: EMA/Casadei shaper spindle bearing ...
Bearings are cheap, if you have not found it yet find the bearing place in your area. I'll bet bearings are less than $50 or $75 for that spindle.
Try Motion industries they are all over the country.
