Solid Wood Machining
Planer indeed rollers
1/30/21
Roger Wilson
Website: http://wilsonwp.com
I have a JA Vance planer matcher. I need to have new infeed rollers made. Any suggestions on how the diameter of the infeed should compare to the outfeed. Thanks
1/31/21       #2: Planer indeed rollers ...
Dustin Orth
They should be the same outside diameter if the feed mechanism for each has the same rpm. Measure the pulley or teeth if its a gear, if those are the same, then the indeed roller should match the outfeed roller. If not, they will run at different speeds and cause all sorts of issues.
2/1/21       #3: Planer indeed rollers ...
Is it missing or dull. I believe they can be sharpened.
11/26/21       #4: Planer indeed rollers ...
AcctekChina Member
Decide which one to use according to the size of your raw materials, the size of the output, and the output.
