Solid Wood Machining
Problems with Felder F700Z shaper (2021 model year)
3/1/22
Dan Member
I recently received this machine new. While it's very nice overall, there has been an issue with the digital height control of the spindle, (among other issues that have been resolved). The fast raise/lower lever works fine, but the slow raise button, used to dial in the height, moves way too fast, so it is difficult to dial in the height exactly. Felder has given me the run-around for over a month now, and today basically said they aren't going to do anything, just live with it. There are more details on this I can go into if anyone is interested, but I'm wondering if anyone else has had a problem like this?
3/1/22       #2: Problems with Felder F700Z shaper ( ...
Chris
I have the format4 version and have been fairly happy with it overall. Felder service has always been hit or miss in my experience (I have 7 of their machines) . Not sure where you’re located but if you don’t have luck getting your dealer to resolve the issue, contacting the factory directly may help.
One press of the button results in the spindle height moving .1mm on my machine.
3/1/22       #3: Problems with Felder F700Z shaper ( ...
Dan
Thanks, Chris. I purchased the machine directly from Felder, and tech support has been in touch with Austria. They are saying because the 3-phase voltage at our building measures 247 instead of the target 230, they will not honor the warranty claim. Even though their documentation supplied with the machine says the voltage can be within +/- 10%, which 247v is. I doubt that’s even related to the problem.
3/12/22       #4: Problems with Felder F700Z shaper ( ...
Gary
Dan,
I have the same machine and i don't like that aspect of the machine ( slow raise button too sensitive) but I have learned to live with it.. I just assumed that was the way it was designed. I also contacted Felder and suggested they put a hinged cover over the start button. It is way too close to the height adjusting buttons and I have hit by accident several times. Not Safe ! I took the plug cover off my Festool vacuum and , with some two sided tape, now it covers my start button with a hinged cover. I hope they make the change.
3/24/22       #5: Problems with Felder F700Z shaper ( ...
Dan Member
Gary,
One thing that may help some, if you haven't tried this already:
The speed on the raise/lower motor is dependent on voltage. For whatever reason, there are two taps that can be used to supply the voltage to this motor. The machine is apparently shipped with the motor connected to the higher voltage tap (~10v). You can switch the wires supplying this motor to the other tap (~5v). This will slow it down a little. It's still way too fast, but it helps a little. These wires are connected to taps on the the "T1" block, iirc. Contact Felder tech support for details. It's not too hard to do.
I'm dumbfounded that they sell a machine that operates this poorly in this regard. It seems like it would be easy engineering fix in the electronics.
I have not personally had a problem with the start button triggering accidentally.
