Solid Wood Machining
Door sticking on the moulder
3/2/22
Chris
I have almost zero experience with moulders. A few classes on an old 5 head weinig in college, but not much other than that.
Is a 4 head moulder like a Quattromat suitable to run door sticking? Could someone share the basic setup for this operation? Sticking cutter on right or left spindle? Face up or down?
Is there an appreciable difference on this type of profile run on a 5 head vs 4 head ?
We currently rip, face, plane, run sticking with outboard fence on the shaper, size for width with spiral head and outboard fence on shaper.
Would the moulder allow for rip, moulder, done?
3/3/22       #2: Door sticking on the moulder ...
Doors? What kind of doors?
-Cabinet doors
-Passage doors
3/3/22       #3: Door sticking on the moulder ...
Chris
Sorry, should have been more specific. Cabinet doors. 20-25mm thick
Just started reading your book by the way, great so far.
We are mainly a kitchen/ custom cabinet shop so I’ve never built a passage door.
Also based on your book I know that you once had a quattromat. Did you ever run passage door sticking through there or just s4s and then through the shaper? Maybe this is discussed in a later chapter.
3/5/22       #4: Door sticking on the moulder ...
Yes, cabinet door parts are a dream on the Quattromat or similar. The machine has a length limitation that I can't remember - 12" or so. But since it can flatten and straighten, it can make perfect stock in one pass.
Run rails at grouped lengths, then cut to cope after
profiling. We always did our profile on the outboard head. Get the longest infeed table and fence to augment the straightening functions.
We used the machine for S4S on our stile stock, and what rails we could get thru. We did not profile since the spindles were different diameter. We also crowned stiles, so blindly running stile stock lost our ability to crown them. It was not unusual for the machine to make a batch of stiles for 20 doors before lunch.
Cutoff at Radial Arm saw, then Rip on the Straightline, then S4S, then profile on the Shaper.... 20 doors, skipping face and edge on the joiner would save about 6 hours, or $600 at today's rate. Once a week x 4 is $2400 month. So a $30,000 machine would pay itself off in 13 months. Even saving only 1.5 hours a week will pay off the machine in 5 years.
I think you will find there are a lot of machines used for passage doors that will really speed up the cabinet door manufacturing. Ripsaw, 4 head machine, widebelt, just to start.
And on the business side, this makes you a more complete and attractive vendor. Once you sell a cabinet job, then you are halfway to selling the passage doors, and vice versa.
3/12/22       #5: Door sticking on the moulder ...
Dustin Orth  Member
Before I sold out of a cabinet shop, I had already bought a molder to start making trim and did a ton of lineal stock thru it for face frames and door parts. It made life so much easier! One thing to keep in mind, molders generally have much bigger spindles than your shapers so swapping tooling back and forth isn't always possible. Buying a molder also opens more doors of what you can offer your customers. Good luck!
6/21/22       #6: Door sticking on the moulder ...
JR Rutter Member
We do mostly S4S for rail/stile stock on a 5-head moulder. As David mentioned, once you run a sticking head on it, you limit your ability to crown the parts. For certain styles, like mitered or haunched bead doors, we end up chopping the long rips down and crowning on the moulder infeed side. This creates more waste of material and time, so isn't ideal.
