Solid Wood Machining
wide belt sander trouble
3/16/22
dan summerhill
We have a Powermatic 37/60 sander. It won't read some belts. Within a box, some belts work fine and then one belt will not read the eye and shut the machine off. We tried painting the edge of the belt white, per Powermatic, but the eye still won't read. This has been going on for 15 years. if a belt doesn't read once, it never will. If it reads, it always will
3/18/22       #3: wide belt sander trouble ...
Acctek  Member
If the abrasive belt deviates, the damaged parts should be replaced in time to improve the dust removal effect.
3/18/22       #4: wide belt sander trouble ...
door shop guy
Your Powermatic has an electronic eye? Mine is 1997 model with air eye.
3/21/22       #5: wide belt sander trouble ...
Spray at least the first inch of the belt backing material with black paint on both sides. Or buy a heavier weight backer. The "eye" is seeing through the backer.
3/23/22       #6: wide belt sander trouble ...
KenW
If its an electronic eye, place a piece of scotch tape over the eye. That has worked on every sander I have ever had an issue with. Was taught to me by a 3m rep.
5/12/22       #7: wide belt sander trouble ...
Adam West  Member
Some electronic eyes will see through a belt if the eye is too sensitive. Some eyes have a sensitivity setting you can adjust.
