Solid Wood Machining
Motor brake for table router.
6/17/22
CMC
How can I build a 110v motor brake for a 1.75hp table router.
I want the router to come to a stop the same way a mitre saw would.
I currently have an aux on/off switch and speed control on this setup.
Do miter saws have this feature within the switch, could it be adapted?
School me!
6/17/22       #2: Motor brake for table router. ...
Leo G
A miter saw switch disconnects the power while shorting out the motor. The short circuit produces a strong magnetic field in the opposite direction causing the motor to come to a stop much quicker than it would do by spinning down.
Routers are usually multi-pole winding motors. I would suspect it should work the same.
6/18/22       #3: Motor brake for table router. ...
That's going to be exciting, braking a motor running at 20,000rpm. Better order a couple dozen brushes while you experiment!
6/20/22       #4: Motor brake for table router. ...
CMC
I did find a setup that should work.. but the price is 3 times what the router cost... https://odiz.com/product/makesafe-tools-power-tool-brake/
Is there a router available on the market with a brake feature as standard?
Hi Leo, so run the router, unplug it (with the switch still in on position) and short the plug? This should be the same as what your mentioning?
6/20/22       #5: Motor brake for table router. ...
Leo G
It should be.
6/20/22       #6: Motor brake for table router. ...
CMC
So I tried that just now.. It made no difference to the motor coming to a standstill.
6/20/22       #7: Motor brake for table router. ...
Leo G
Must be the multi-pole setup of the motor. It's not a universal motor like chopsaws are.
Easy enough to test for, and only cost you a few seconds to do.
Now we know.
6/21/22       #8: Motor brake for table router. ...
Hen Bob Member
upgrade to a shaper?
6/26/22       #9: Motor brake for table router. ...
Acctek  Member
stepper motor?
