Solid Wood Machining
Wood engraving on fiber engraver
5/31/22
MrKyle Member
Good afternoon!
Initial data: Raycus 50wt , 200*200
Material: Plywood, solid oak.
Task: To get an engraving.
After reading the manuals, it became clear that a fiber engraver cannot engrave wood. However, some of my colleagues in the workshop do such engraving, claiming that they have fiber engravers.
As far as I know, wood engraving can only be obtained on CO2 or CO2 electroplating machines.
If I'm still wrong, please tell me the approximate parameters for such an engraving for testing.
5/31/22       #2: Wood engraving on fiber engraver ...
I would try a softwood before I give up on your laser. Pine, Fir, Spruce are readily available. The softer fibers will respond to the heat of the laser.
5/31/22       #3: Wood engraving on fiber engraver ...
The main reason not to use a fiber laser on wood is the wavelength of the laser. The shorter wavelength partially transmits through the wood and can easily start a fire. The second reason is uncontrolled absorption in the wood and an unreadable engraving.
7/14/22       #4: Wood engraving on fiber engraver ...
Acctek  Member
Using a CNC engraving machine is better for engraving plywood, solid oak
7/20/22       #5: Wood engraving on fiber engraver ...
Rude Member
If you ask me, oak is better for using a CNC engraving machine. Also, need to have a flexible CNC machine.
