Solid Wood Machining
Straight Line Rip blades
8/4/22
MrFee
Website: http:/
After 8 months in a cabinet shop, I am trying to take over the responsibility of machine maintenance. The previous foreman of several decades left in a hurry and took a lot of tribal knowledge with him. Things he wouldn't teach guys or explain why or when we do things. Yesterday I heard the rip saw struggling, opened it up, and found an 80 tooth miter saw blade in there... What blade characteristics should I look for in a SLR blade? I was thinking a low tooth TCG but am not sure. What blades do you use? We are mostly ripping maple or alder. Should we use different blades depending on wood? I know this is getting in the weeds for a saw that just cuts straight but I'm trying to improve processes and quality.
8/4/22       #2: Straight Line Rip blades ...
Chris
Check out Forrest mfg.
Definitely way too many Teeth per inch.
What size blade do you use?
8/4/22       #3: Straight Line Rip blades ...
MrFee Member
12" 1" bore
8/5/22       #4: Straight Line Rip blades ...
chris
you will need a blade with about 24 teeth. Not 80
8/5/22       #5: Straight Line Rip blades ...
Dave Edgerton
We use Royce 12" 24 tooth tcg ripping blade
8/5/22       #6: Straight Line Rip blades ...
TCG tooth profile. Thick blade plate. - .160" or so. Expansion slots with copper slugs.
15 - 20° hook angle
(More angle for softer woods or less hp, less angle for hardwoods and more hp)
24 teeth for a 12" blade.
FS Tools made in Canada are good as are many other manufacturers. Talk to a company rep who can guide you through their products.
8/6/22       #7: Straight Line Rip blades ...
Find a local tool supplier to help you get and use the best tooling for your (bosses) money. If no one local, try C. G. G. Schmidt. Ask them what is best for your saw. or go to the saw machine manufacturer to find out what they recommend.
In the bigger picture, ask you questions here. Lots of smart people that are willing to help other woodworkers become better woodworkers. As Gary Katz says "Study your Craft".
