Solid Wood Machining
Thick moldings
11/17/22
Thomas Soyk
Hi All
We are looking at a large commercial project that requires 12/4" and 16/4" thick Cherry moldings.
Our past experience (10 years+ ago) has been that there is alot of stress in the lumber and it tended to "curl" when ripping.
We would prefer to not laminate for thickness because the labor would be too costly.
We have been given the option of Soft Maple if we do not feel Cherry is viable.
Thank you in advance,
Tom
11/17/22       #2: Thick moldings ...
Some drawings showing the profiles would help, but no way would I hang that thick of cherry. IF you could even find it. I would ask for a consult with the architect and discuss build up moldings. None of this job should cost you too much money. You bid at the price you need. Worry about being too high is a great way to loose money!
11/18/22       #3: Thick moldings ...
Thomas Soyk
Rich
Thank you for the advise.
We are able to locate up to 16/4" Cherry. Since Cherry has fallen out of favor in recent years they are not rushing the drying process and it should be more stable than it used to be.
Also, we are definitely building the profile up with plywood backers as able.
I was hoping for feedback from someone that has actually milled some 16/4" Cherry recently .
11/21/22       #4: Thick moldings ...
Why in the world is Soft Maple an alternate to Cherry?
11/21/22       #5: Thick moldings ...
Thomas Soyk
Availability
11/25/22       #6: Thick moldings ...
Depends entirely how much of the blank you are hogging out.
If it's a lot being removed, I'd figure out how to break it up somehow so they can be stacked.
Laminating would be tough, but still a better option as far as stability goes.
