Solid Wood Machining
RE: Wood Slab Surfacing Machines
11/25/22
Kenneth
Does anyone know of any Wood Slab Surfacing Machines, similar to the Wood Wizz, that I could purchase used?
11/28/22       #2: RE: Wood Slab Surfacing Machines ...
Bruce H
You can make one using liner bearings and rails from Amazon and a router. As for the larger machines there are several companies making them. Just have to watch Craig's List for a used one. Most likely not real common.
11/29/22       #3: RE: Wood Slab Surfacing Machines ...
80/20 might work well for making your own as well
11/30/22       #4: RE: Wood Slab Surfacing Machines ...
I have a hard time imagining what 10' sticks of 8020 would look like after getting delivered from a semi. Let alone the shipping cost!!
12/9/22       #5: RE: Wood Slab Surfacing Machines ...
Easy solution to that, find a local wholesaler, and have them order it in.
The garage warriors build cnc's outta the stuff all the time.
12/30/22       #6: RE: Wood Slab Surfacing Machines ...
Ken Member
Sort of depends on the capacity you want. It's on them to get it to you in the right condition.
