Air Compressor Troubleshooting
12/9/22
Website: http://www.davidwinterswoodworker.com
Air pressure drops to near zero psi as soon as a tool is triggered.
It's a big Saylor Beall compressor with a filter and regulator inline.
Bad regulator or filter?
Thanks so much in advance!
Dave
12/10/22 #2: Air Compressor Troubleshooting ...
Do you regularly drain condensation from the compressor tank?
12/10/22 #3: Air Compressor Troubleshooting ...
Probably not as often as I should...but I don't see how that could produce my symptoms.
12/10/22 #4: Air Compressor Troubleshooting ...
If the tank is half full of water, you have very little capacity.
12/12/22 #5: Air Compressor Troubleshooting ...
Filter or regulator. Look at both. Another possibility is that any black iron fittings could be packed up with rust. Start with the filter elements. If you haven't replaced them before then they are due. Next replace the regulator if necessary.
12/12/22 #6: Air Compressor Troubleshooting ...
Website: http://davidwinterswoodworker.com
Thanks, all.
Replaced the filter and now all good.
Again,
Thanks!
12/13/22 #7: Air Compressor Troubleshooting ...
With a clogged filter I would inspect the tank for any rust and also the condition of the metal fittings. The contamination is coming from somewhere and you don't want a tank failure. Google images of tank ruptures.
