Solid Wood Machining
Moulder question
3/7/23
Chris
How many of you running moulders have the rabbeting cutter on your first bottom head to create a reference edge? I looked at a new Leadermac today and it doesn’t come with one, and the fence before right side head is full height.
would this hinder the ability to straighten material? Thank you
3/7/23       #2: Moulder question ...
Dustin Orth
My current molder doesn't have a reference engraver and I just ordered a new molder and it doesn't come with one. You could request one but they say hardly anyone is asking for them.
3/8/23       #3: Moulder question ...
Fred
Hi Chris,
We have a13 year old 12" wide Leadermac that came with the rabbeting cutter. It defiantly helps with straitening the stock. We run a lot of door components with it.
You have to keep checking that the secondary fence that lines up with the rabbet cutter for staying stays parallel with your main fence. And stays lined up with your rabbet cutter. Also have to keep good inserts in the rabbet cutter.
If you don't stay on top of this you have problems or you have a mark left on your finished edge from the rabbet cutter. I don't work much on the moulder anymore, but when I get back on it it is often one of the fist things I need to correct.
