Solid Wood Machining
What does your shop use for crosscutting face frame stock?
4/8/23
P. K. Member
I'm looking to upgrade my cross cutting for faceframe stock.
99% of the time I'm cutting 1-1/2" & 2" stock with 5-1/2" once in a blue moon.
I've only worked in small cabinet shops using off the shelf mitersaws (original Delta Shopmaster, Dewalt, Bosch).
The saws are set at a stateion with kreg/woodstock rulers and stops.
I've used I've used 50 year old 10" radial arm saws rough cutting material at a few jobs and did not care for them.
What do you use to cut your face frame stock?
4/8/23       #2: What does your shop use for crosscu ...
Dustin Orth
When I was building cabinets, I set up a 16" jump saw with a custom build fence like a tigerstop. Cuts square every time and with a computer fence, you can fly through a cut list.
4/8/23       #3: What does your shop use for crosscu ...
Dave Edgerton  Member
We use a sliding panel saw. Not the best due to speed but its a nice cut. An upcut saw would be ideal for us.
4/9/23       #4: What does your shop use for crosscu ...
Upcut saw and digital stop with cut list fed digitally to the fence.
4/12/23       #5: What does your shop use for crosscu ...
Andy Ryals  Member
I bought a 90 degree chop saw from CTD about 5 years ago for a similar purpose. I have used all methods mentioned above and this tops them all, by far.
4/14/23       #6: What does your shop use for crosscu ...
Sled on my tablesaw with a digital gauge. Longer than 50" I bind them together with a clamp and cut them at the same time so if the length is a bit off they are still all the same and you can fake it with a slightly wider stile.
4/16/23       #7: What does your shop use for crosscu ...
Jim b Member
I upgraded my table saw and instead of getting rid of the unisaw I made sliding table to left of blade.still tweaking it just haven’t had time but I think it will work for me cutting wider solid wood.I have 1265 panel saw for plywood
4/17/23       #8: What does your shop use for crosscu ...
Jim
I have a CTD saw and biesemeyer fence and stop
Very well built saw. Flip it on in the morning and it will bang parts all day like it's nothing
The fence and stop are low tech but accurate but work fine for door parts at our volume
4/20/23       #9: What does your shop use for crosscu ...
Northfield 12" jump saw with a Razorgage stop.
Used a Omga mitresaw for years. Still use them on the benches for odds and ends, but the bulk of the face frame and door stock on the jump saw.
I had a Whirlwind, and a Cantek prior to the Northfield saw. The Northfield is hands down better. I also like the Razorgage more than the Tigerstop I had before. I think the interface is better, and holds numbers with less recalibration.
