Solid Wood Machining
Need replacement switch recommendations for Martin T17 tablesaw
4/22/23
correy Member
Hi guys, I have a T17 that the controls are faulty. Most components are obsolete. I'd prefer to just put a new switch on the machine.
I am going to by pass the scoring motor, not needed.
The motor I believe is a 3ph 7hp with a basic 4 wire leads. No neutral as far as I can tell. I believe the original controls may have had a ramp up in the start sequence.
I don't really need variable speed as the saw is set up for 3 speed mechanically. Any thoughts? If te motor needs the "soft start" I seems a basic magnetic switch may not be the right route to go.
Thanks for any help.
Correy
