Solid Wood Machining
Why is a "clutch" on a thickness planer?
5/4/23
Pdub
We have an older Powermatic P180 that's been a great machine. We've updated it with a Helixhead (Hermance) and tweaked it over the years so it's been a great workhorse. Recently, the clutch has been popping out. Turns out the clutch drive "gear" is completely worn down because over the years, the clutch handle that sticks out has been continuously hit by someone walking by and has ground a cove into the previously squared edge of that gear. We are now trying to find obsolete parts to repair it. I might have one made and in doing so, disable the clutch so this doesn't occur again in the future.
My question is, why is that clutch there in the 1st place? If something gets stuck while feeding? When that happens to us, we usually slightly lower the bed and push it through. Or we turn it off and pull it out. So if I disable the clutch completely, am I in any danger of hurting the machine or an employee in any way when something goes awry?
There will be another post asking if anyone has a broken machine to pull parts from!
5/5/23       #2: Why is a "clutch" on a th ...
It is a simply convenient way to stop the feed of the machine for any reason. You also don't lose your thickness setting if you are doing critical work. I have seen that clutch pop out if not fully engaged.
There was a Bill Kerfoot about in the machinery section that rebuilt the older Powermatics - sold renewable parts - and he may be able to supply the part.
Those Powermatics from the P120 to P240 widths are the finest small shop planers ever made. Plenty of power, accurate, fast, smooth, etc. There are plenty of them around since at one time nearly every secondary school in the US had at least one.
5/5/23       #3: Why is a "clutch" on a th ...
Pdub
That's what I assumed. So, not really necessary and I'm not going to damage anything by disabling it. We have an Accurate Technologies digital readout attached to the machine, so we can repeat precision.
Yes, we are "small enough" that with all of the upgrades and modifying, the P180 does a great job. About once every 2 years I want a bigger one, but if I can fix this one, she likely won't ever leave the shop.
I found an old post of yours recommending CS and giving Bill's contact info. I'll reach out. Much appreciated David.
