Solid Wood Machining
Three phase question
5/11/23
Pete
Figured I would ask this question here instead of killing time going through back forum questions.
My situation- small custom furniture shop, 100 amp feed which runs a 10HP rotary converter. If I get a 12 hp shaper am I correct to think that I would need to have another machine running for it to start?
Thanks in advance.
5/11/23       #2: Three phase question ...
Dave Edgerton  Member
It would probably start the shaper as its not heavy load to start. But no if you have another machine running that is a load on the phase converter, not additional capacity. For additional capacity you would need a second equal phase converter.
Once the shaper is running, the 10 hp phase converter can handle up to 22 hp load. Its the startup that is hard. We started a 10 hp sander on a 7.5 hp phase converter but it was hard on it. We since installed a 40 hp one on a 200amp service.
5/14/23       #3: Three phase question ...
Ken Member
The having a motor running is for when you have a static convertor. If you start a large motor with a static convertor you can start smaller motors. Static convertors are sized to a hp range i.e. 5 - 7 1/2 hp. If you have this large motor running you can start a 1 hp motor. If you tried starting the 1hp on that static convertor by itself it wouldn't start. I currently run a 20hp rpc in the wood shop and a 10hp in the metal shop.
5/19/23       #4: Three phase question ...
correy
Website: http://matsukazewoodworking.com
Typically you need at least 50% more Ph conversion than HP to start depending on machine type.
My 10hp planer still had trouble starting with 15hp total ph conversion. Which was two 7.5hp rotaries.
Instead of buying more conversion , Phase-a-amatic built a torq booster for a few hundred bucks for me. It acted like a big capacitor and gave a little extra boost at start up. Worked great. They are not listed on their site, you need to call and they will come up with a plan for you.
Another option would be to just get a Phase Perfect which supposed to start a 10hp motor with a 10hp converter. It's probably the route I will go if I move to a single phase location in the future.
7/11/23       #5: Three phase question ...
Brian Member
Not really answering your question. I have a 100 amp panel in my shop. I run 2 American Rotary 20 hp RPC in my shop. They each are fed by a 60 amp breaker in my 100 amp panel. Originally I had one 20 hp RPC. It ran my 9 hp slider and 5 hp DC. I bought a 20 hp widebelt. Widebelts have a huge draw on startup. To keep the RPC’s balanced you need an equal hp RPC so I was required to buy another 20 hp.
