Solid Wood Machining
sharpening moulder knives
5/12/23
Kevin
Hi all,
I'm new to grinding moulder knives (about 5 months). I occasionally get a white line on mouldings that is caused from a dull spot on the knives after a sharpening. I hone the backs of all knives with a fine stone and use a diamond impregnated rubber stone to work the burr off from both sides of the knife tip. Any tip or other methods you are using to de-burr moulder knives before running them?
5/17/23       #2: sharpening moulder knives ...
Dustin Orth
Are you using a scope to inspect your knives? I have found you can actually see little burrs if you know what to look for.
5/18/23       #3: sharpening moulder knives ...
Kevin Member
I have never been able to detect burrs in my knife edge on the scope. I sure can see the dust and lint from the rag I wipe the honing oil off with.
8/22/23       #4: sharpening moulder knives ...
Steeliemark
Could your knife be hitting a bit after the edge due to too little back clearance?
8/23/23       #6: sharpening moulder knives ...
Kevin
I have gotten some great advice from my saw and tool shop Vexor. I am now grinding 25°, honing the backs of the knives after every grind, then I go to 20° for a very fine grind to finish the edge and hone again. This seems to have eliminated the dull spots on the edge and I have sharper edges than ever before.
Thanks everyone for the responses!
