Solid Wood Machining
Shaper spindle
8/11/23
Brendan Harris Member
Website: http://www.parkervillewoodproducts.com
We have an SCM T155 Nova Shaper with a tilting spindle. While removing the head, the spindle loosened and came out with the head on it. We removed the head and when we put the spindle back on to the machine, the spindle seemed to be seated properly and be tight with only one revolution on the threads. We have not taken the spindle apart but it doesn't seem like anything could have changed. The threads are course and it would seem that this should thread on with 3 or 4 revolutions', not just one.
Can anyone help me. We are reluctant to run the machine.
8/13/23       #2: Shaper spindle ...
You probably cross threaded the spindle when you put it back in. Carefully inspect the threads.
9/4/23       #3: Shaper spindle ...
BH Davis  Member
It's been a number of years but as I recall if that machine is anything like the SCMI T-110 shaper there are two different threads involved. On the T-110 you had to retract the nut almost entirely before threading it onto the machine. Then as the larger bottom thread seated the smaller upper thread sucked it all tight.
I always considered it a strange and awkward system.
I would not run the machine until I sorted this out. It could be quite dangerous.
Sorry I didn't see this sooner. Hopefully this has long since been resolved.
10/23/23       #4: Shaper spindle ...
David R Sochar  Member
Website: http://www.acornwoodworks. nzs5z967fd com
I agree with Bernie. The SCMI machines have two sets of threads, one is very “fast” and tightens the two parts, the second, finer threads lock the collar into place. The machine has a vary large socket for tightening the larger nut. This is often cast aside as no one sees a need for it. Spend twenty minutes with it, inserting and removing, turning the nut, removing it, etc. if you don't see the light bulb go off , then you need to find another line of work.
