Solid Wood Machining
Seized axial / radial adjustments
11/19/23
Chris
I just bought a used Weinig quattromat and the top axial & left radial adjustments are seized. Could someone explain what’s needing to be done to get things freed up and moving smoothly again? The left axial adjustment also seem to have quite a bit of backlash in the threads (more than other heads), is there an adjustment to help with this? Thanks
11/27/23       #2: Seized axial / radial adjustments ...
Dave Edgerton  Member
Pb blaster for blts and work ema bit. Is there a lock bolt on them? Typiically they are locked down after adjustment.
