Solid Wood Machining
using a molder as a 2 sided planer
12/22/23
CRIS
We are looking to streamline our drawer box side machining process. would a 5 head molder work for us. Mtl. is 15/16 in 5/8 out 12 in width max Looking to trim width to final size apply dado plane bottom plane top and add chamfer to 1 edge. Allowing for glue up mismatch we will be removing approximately 3/16 in from both top and bottom .My concerns are the holddowns kickback
12/22/23       #2: using a molder as a 2 sided planer ...
I've not been in big production shops, but do 5 head machines come with that kind of width capacity? The 5 head would not take out all the cup or twist of the stock.
12/22/23       #3: using a molder as a 2 sided planer ...
A moulder should give you some straightening ability on the first two heads. Not like a skilled operator and a jointer, but pretty good.
12/23/23       #4: using a molder as a 2 sided planer ...
Fred Frehner
Hi Cris,
We have a 12" Ledermac. Depending on the tooling in the outside head we can run up to 11 1/2" wide.
If we had raw stock that was not so flat we sometimes plane it oversized (in the Moulder) first to pre straiten it. Its an extra step but you can save a lot of material and get a much better straighter product.
12/23/23       #5: using a molder as a 2 sided planer ...
Dustin Orth
I use my molder all the time doing just this type of stuff, only out to around 9". Have you looked at the price of a 12" capacity molder? You would need to run a LOT of material to make it pay for itself. I just saw a used 12" 6 head machine for sale, around 85,000 if memory serves. That's a lot of drawer boxes. Anytime someone asks for 12" drawer stock, I run it old school because normally it's not a ton of lineal feet. The 3" up to 8" is usually hundreds of feet vs 20 or so per kitchen. Is the high cost of that 12" machine worth it? I would love one in my shop but it's rare that anything is over 9"
12/25/23       #7: using a molder as a 2 sided planer ...
Dave Edgerton  Member
A 5 head is the wrong machine for that kind of width. You need a top and bottom planer.
2/28/24       #8: using a molder as a 2 sided planer ...
David William  Member
A 5-head molder could streamline your drawer box side machining process, but ensure proper safety measures and consider kickback concerns with the holddowns.
