Solid Wood Machining
Kupfer Muhle Planer
1/7/24
Kurt Member
Hi Folks. Anyone out there own one of these German made planers? I purchased a 4 sided one sight unseen (i know, i know) and a bit overwhelmed by the work it needs. Not afraid to tackle it, but cant find much info online about them. Just want to ensure the end result is a machine worth the effort. Worst case it dimensions rough stock from the mill for framing material. Best case its accurate enough to put in the shop for dimensioning hardwood for cabinet doors. It has 35mm spindles and I got a bunch of corrugated cutter heads with it. Right now running everything through the jointer then planer, table saw ect. Time consuming to say the least but good finish.
Thanks in advance.
Kurt.
1/9/24       #2: Kupfer Muhle Planer ...
David R Sochar  Member
Website: http://www.acornwoodworks. nzs5z967fd com
I bought a Pinhiero 4 head planer at one shop. A Spanish machine imported by some guys in Maine, it had a learning curve. Bottom head, like a joiner, to0 headbexy, then side heads that looked like afterthoughts. They showed pics of it making log cabin log profiles. We used it to produce S4S lumber all day long. Once it was set up by someone that learned how to dance with it, it was great. 30 l/f a minute, all day long, that beast could make some money. But don't sneeze by it. I wanted a Kupher
Muhle, but at twice the cost ($60,000 in 1980) just could not swing it. In hindsight, it would have paid its way in a year.
1/9/24       #3: Kupfer Muhle Planer ...
Kurt Member
The Pinhiero is a similar looking machine. The Kuper also appears as if the side heads were an afterthought, probably due to the many configurations that were offered….a 24” double sided planer being the platform.
Crazy, 60k in 1980. I think mines a 1978… still a baby.
Slowly getting it cleaned.
