Solid Wood Machining
scm 20" planer outfeed
1/10/24
tom e
I'm looking to have the outfeed roller recovered on a 2004 scm s520e. It looks like newer models unbolt easily, but this one is a previous generation - there is a center rod with a pillow block type assembly on either end. Drive sprocket and rubber roller cover are held by one set screw each.
Anyone know if I can get the rod out by removing one of the pillow block/bearing assemblies, or do I have to remove the entire top end?
thanks!
