Solid Wood Machining
Wide belt needs help!
1/29/24
duster
One of the 4 lead screws that raise and lower the table on my 36" wide belt sander seems to have seized. I've cleaned it and lubed it, but it's still bound up. The machine is 25 years old, and the rest of it still works well, but the Tiawanese manufacturer is no longer in business. Changing out the lead screws looks to be a tough job, even if I could find suitable replacement parts.
The machine is an integral part of my operation, but I'm close to retirement and don't feel like dropping a bunch of money on a new one. Any suggestions?
1/30/24       #3: Wide belt needs help! ...
Try a high end penetrating oil like Kroil. Some people rave about a 50/50 mix of acetone and automatic transmission fluid.
2/7/24       #4: Wide belt needs help! ...
Todd Member
Hey Duster, did you ever get this out? I can count on one hand the times PB Blaster hasn't worked, and although I've never used it, sewing machine oil is supposed to work well as it's extremely thin.
Todd
2/7/24       #5: Wide belt needs help! ...
duster
After spending a few hours working on it, I realized the problem is more extensive than I originally thought and this machine is fubar. I'm a little sad because it was a good machine and did a lot of work for my shop. I found a nice late model SCM sander at another shop only 5 miles away, so I'm going to grab that.
