Solid Wood Machining
Kolle F45-m Shaper Schematics
4/15/24
Benjamin J Neumann Member
We are having an electrical issue with our Kolle shaper. The company went out of business years ago & we are now finding that we are missing the electrical schematics. Hoping that someone out there has a copy to share. The machine is an F45-m manufactured in 2000. Anything around that era may be of use to us. Thanks in advance!
2/3/25       #2: Kolle F45-m Shaper Schematics ...
Kurt Member
Were you able to resolve your issues with your Kolle?
I do not have any manual's but I have the same shaper. If there are any tests, or readings you would like me to check let me know.
Kurt.
2/3/25       #3: Kolle F45-m Shaper Schematics ...
Benjamin J Neumann
Thanks Kurt! We found an industrial electrician who was able to trouble shoot & repair the machine.
2/3/25       #4: Kolle F45-m Shaper Schematics ...
Kurt Member
Oh great! Good to hear. I love my Kolle! Too bad they are no longer.
Do you have a 22mm bolt at the top of your spindle? I assume its for spindle removal, but never really investigated. My SCM spindle is internally threaded for a cap screw if you were using that for securing cutters instead of the external nut but the Kolle is definitely different.
Thanks!
2/3/25       #5: Kolle F45-m Shaper Schematics ...
Benjamin J Neumann
Yes, that bolt is for removal of the 32mm shaft. We have additional tool holders with different size collets for running traditional 1/2" & 3/4" shank router bits.
