Solid Wood Machining
Water cooled spindle in router table?
4/13/24
jamien Member
Just scrapped by 2nd 4.25" router body after the bearings proved impossible to replace. I'm not impressed with all the similar options - they all look like the same motor with different color plastic basically.
Has anyone tried using one of the cheap 3kw water cooled spindles in a router table? i like the concept, and the ER collets. it seems feasible, but i can't find anyone who has done it. Obviously i'd have to make, or have made some kind or adapter to fit the 100mm body to the 4.25" lift, but otherwise it seems pretty simple: hook up the vfd and pump and hit go. am i missing something?
I am a small shop with a shaper for most things, but the router table with power feed does get used to make simple small moldings, sometimes in big runs which is why the bearings go i think. and they are cheap routers, no mater what brand sticker is on it.
4/14/24       #2: Water cooled spindle in router tabl ...
Ken Member
First off what kind of router motors are you using? I have several 7518 and 7519 PC that I've changed the bearings in just fine. Those bodies are 4.20, not 4.25 so a simple shim takes care of that. I also have some older Rockwell, (like PC) routers that have a larger body (I'll have to check those).
4/14/24       #3: Water cooled spindle in router tabl ...
I wouldn't suspect that what you called "cheap" spindle would have any better bearings in it. I've never had a router that couldn't have the bearings replaced. Somebody put them in there, replacing just takes knowledge and tooling. That impossible to replace must be a personal evaluation. Water cooled needs more support equipment and distilled water treatment.
4/15/24       #4: Water cooled spindle in router tabl ...
jamien Member
I have never had on of the older PC motors, if i found one i'd definitely take it.
First one to fail was a porta-mate second was a different brand, but from what i could tell indistinguishable inside (different plastic outer body). The armature/shaft main bearing is fine to replace. But at the end away from the collet is a smaller bearing that in both cases was cast into some sort of resin and also the speed control board. i was unable to remove it and keep the resin portion intact enough to reassemble properly. after removing the speed control portion i did get it to spin again, but it was out of balance and i gave up. So sure, the bearings could be replaced by someone who is better at it, but i can't and would like a better solution. It was clearly not a user serviceable design.
4/16/24       #5: Water cooled spindle in router tabl ...
Will Williamson  Member
I have 2 or 3 of those older Porter cable routers I would be willing to get rid of. 2 of them have fresh bearings and brushes.
4/17/24       #6: Water cooled spindle in router tabl ...
BH Davis  Member
Pick up a Porter Cable 690 router. Either new or used. They basically last forever.
5/7/24       #7: Water cooled spindle in router tabl ...
trueframe Member
Website: https://www.trueframe.in/
Solid wood machining is the process of shaping and cutting solid wood materials to create desired shapes and sizes. It involves using machines like saws, routers, and planers to transform raw wood into finished products such as furniture, flooring, and cabinetry.
5/8/24       #8: Water cooled spindle in router tabl ...
duster
I wish Woodweb would filter out these inane AI responses...
5/9/24       #9: Water cooled spindle in router tabl ...
Ken Member
Yes Trueframe, and lemonade is the process of mixing lemon juice, water, and sugar. So whats your point?
