Solid Wood Machining
SCMI MiniMax WIN CS63 Bed Adjustment
4/18/24
Isaac  Member
Website: http://www.milkbuilt.com
I recently purchased a WIN CS63 at auction and am having some bed alignment issues. The right side of the bed (or contact roller) is lower than the left side of the bed by nearly 1/32". I mainly use this machine for calibration/light dimensioning so this misalignment makes this machine almost worthless. It looks like there might be some adjustment on the jackscrews that raise and lower the bed but I don't want to start chasing this problem and create another. Does anyone have information on how to remedy this? I can't find anything in the manuals and SCMI's tech service is awful.
4/19/24       #2: SCMI MiniMax WIN CS63 Bed Adjustmen ...
Jonathan Member
Website: https://virmer.com/
It seems like your issue might stem from an imbalance in the jackscrews controlling the bed's height
4/23/24       #3: SCMI MiniMax WIN CS63 Bed Adjustmen ...
Dennis Yamamoto
The Kipp lever and clamp that you have to remove to change a belt is adjustable. I don't remember how I adjusted it, but you can raise or lower the near end of the contact roller by adjusting this clamp. This adjustment should allow you to get your contact roller parallel to the conveyor.
4/23/24       #5: SCMI MiniMax WIN CS63 Bed Adjustmen ...
Isaac  Member
Thanks, friends. Your input is very useful. Going to take a day or two when the schedule opens up to play around with it. I was eyeing the kipp lever and clamp as a possible way to remedy the misalignment but have never seen the adjustment like this on other machines.
6/6/24       #6: SCMI MiniMax WIN CS63 Bed Adjustmen ...
Kia Member
Website: https://wattsan.com/
You're facing a bed alignment issue with your WIN CS63 machine, where the right side is lower than the left by about 1/32". Adjusting the jackscrews might help, but without clear guidance, it could lead to more problems. Explore online forums for advice from other owners, and consider reaching out to SCMI again, explaining the issue. Alternatively, hiring a professional technician might be the safest solution.
