Solid Wood Machining
Moulding Mahogany
5/22/24
John Schultz Member
I've got an order for mahogany to go through our moulder and am looking for some advice. I have zero experience with mahogany and while searching the forums here I see that it's stringy and has problems with tear out. Should I use 12°/20° or 15°/22° heads? Any other suggestions or advice towards a nice smoothe product would be appreciated.
5/22/24       #2: Moulding Mahogany ...
Dustin Orth  Member
I usually use 12 degree and sharpen fairly often. Some mahogany is going to fuzz no matter what you do, especially if it's African mahogany with its swirling grains.
5/25/24       #3: Moulding Mahogany ...
Mahogany is a catch all name. As Dustin mentioned African mahogany except for Sapele are terrible woods to mill. Very hard to plane without getting some chip out. Not as big a problem if using inserts. 12 degrees on the cutters. What specific species are your purchasing?
5/26/24       #4: Moulding Mahogany ...
John Schultz Member
Adam,
It is African Mahogany, sounds like I'm going to be doing a lot of sharpening to keep it clean and smooth.
5/27/24       #5: Moulding Mahogany ...
cartwright4 Member
Use a lubricant or cutting fluid, such as a wax-based or oil-based lubricant, to reduce the friction and heat between the cutting tool and the wood, and to improve the quality of the cut.
5/27/24       #6: Moulding Mahogany ...
cartwright4 Member
Or a slower or more conservative cutting angle, such as 12° or 15°, can be used to reduce the risk of tearing and improve the smoothness and quality of the cut.
6/17/24       #7: Moulding Mahogany ...
BH Davis  Member
Plus don't be surprised if you get a lot of surface fuzz with the Af. Mahog. And it isn't as stable as other mahogany substitutes.
